Layout missing
tihomir
Layout missing
Post by tihomir »
Recent weeks experiencing that the layout is not saved. It comes up with quite some windows missing, or some windows are in a separate OS window. Using 4.5.3.1. It is very annoying to get the layout back manually every time, is there a fix for it?
Re: Layout missing
The layout is not automatically saved. You need to manually save it whenever you think it’s good to go for it.
