Cartwall
Bob Van Dongen
Cartwall
Post by Bob Van Dongen »
Quick question: is it possible to create two or more different jingle groups in the cartwalls? For example, if I play station A, I can only choose jingles for station A, and if I play station B, I can only choose from jingles for station B. I would then have separate folders for stations A and B, containing subfolders with jingles. Thanks in advance, regards Bob
Re: Cartwall
There are already two separate cartwalls.
But there is no station separation.
You would need anyhow two licenses and two instances for two stations.
Bob Van Dongen
Re: Cartwall
Thank you for your quick response. I used the two stations as examples to clearly explain what I was looking for. We have a new design for our station, so I wanted to make a new DB or something similar for the jingles. Regards
