correct media libary
This forum is unmoderated!
Johnny_
Post by Johnny_ »
I have set on hd my musi like these :
G : and then a submap :
1. G1 (2015-2011)
2. G2 (2010-2006)
3. G3 (2005-2001)
4. G4 (2000-1996)
5. G5 (1995-1991)
6. G6 (1990-1986)
7. G7 (1985-1981)
8. G8 (1980-1965)
Whats the correct way to load these on proppfrexx, in de Media Librariers
On map GOld or al these load one for one? .
I hope anybody to help me to understand these.
Schermafbeelding 2026-08-01 181301.png (10.88 KiB) Viewed 3372 times
Re: correct media libary
you can load each individual sub-folder as one media lib.
Plus you can also load the main folder as one huge media lib on top.
It really depends on what you like to achieve in your scripts.
This is hard to say, as it depends on your workflow and scripts.
There is no correct or wrong way…
Johnny_
Post by Johnny_ »
oke, ik wil werken met mood en tags. in thesecase can i say i upload on the media libray all folders on head map.
And tan works with tags on the folder.
Tnks for you feedback.
Johnny_
Post by Johnny_ »
Whats your way if you do these load? only the head map? like "MusicDatabase". or also the subs.
I have now 2k songs in the database.
Greets
Johnny
Sorry, but I don’t understand your question.
Can you explain in more detail.
I have media libs with a few 10-thousand entries and have no issue.
Johnny_
Post by Johnny_ »
I just mean, do you have here in my screenshot the same catogories als on HD.
can you post settings?.
i hope you wil.
Greets
johnny
Schermafbeelding 2026-08-03 082017.png (7.48 KiB) Viewed 3324 times
I am currently on holiday.
But you need to define your own media
Mind. As I don’t use your scripts and setup. Each station is different and your requirements might be different then yours… first I would need to understand your requirements. Then it makes sense to discuss your setup…
Johnny_
Post by Johnny_ »
Hi Bernd i have now right these make on the script. is that a perfect for working with taggs like mood etc. or its these to big for a sript.
I hope you wil check it and give me advice. if possible.
Advice for what exactly?
As the media lins are quite small, I don't see any issue. Do you experience any?
Johnny_
Post by Johnny_ »
i mean, ar the settings orret, i have these playlist dayly set. i want on 20/25 a promo spot from a partner of the show. what the best way work with the overlay sheduler or other. then have i the question i have only run a webstation online. for little group of friends. do i need an airene or is the webstation perfect to work with proppfrexx?.
