Two midi controllers led feedback
Andre Kroon
Post by Andre Kroon »
Hello, i have a question is it possible in Proppfrexx to have led feedback on two midi controllers in the Events/ Commands section?
I use two midi controllers but led feedback is only avallible on the first controller.
Re: Two midi controllers led feedback
The two MIDI devices in ProppFrexx work totally independent (and use the same logic and code, but just use different ports).
So I don't see any reason, why it should only work on the first one - except there is a limitation on the device side.
What 'led feedback' are you talking about?
Andre Kroon
The leds from the buttons of the controllers akai apc mini mk2 and livid ohm rgb.
When i select in midi divices section input 1 and output 1 the akai and input 2 and output 2 the livid controller only the leds of the akai works.
As i put the livid on in and output 1 and the akai in in and output 2 only the livid controller have led feedback.
All the led commands are in the event/commands section do i need programm one controller to another channel ?
Andre Kroon
The midi commands in both cotrollers works fine, only the leds in controller selected in and output1 works as i said.
Can you send the control-command you are using (which is not working) and which events you are using to drive the leds?
Please send a screen-shot or text of the event/commands section.
Andre Kroon
The Livid controller is working but no led pads light up.
Pad is 65
Colour is 31 ( Red )
Note, that you must you use EXEC_SEND_MIDI2_SHORTMSG for the 2nd MIDI device.
In your events I only see commands for the 1st MIDI device.
I.e. EXEC_SEND_MIDI_SHORTMSG vs EXEC_SEND_MIDI2_SHORTMSG
Andre Kroon
Oke,thank you it works, i did'nt see that sorry.
Glad it is working.
