Odd Behaviour regarding REC file locations
PaulLeonard
Post by PaulLeonard »
I just spotted some odd behaviour, and I am wondering if this was intentional.
All channels correctly migrate the recording location from the corresponding setting in the general settings. So, if I change the location there and then rightclick the little R on the bottom of the virtual mixer channels I see the previously set path. However, when the recording is done of the MAIN channel, it is NOT taking over the file path as put in general settings (,but another???). I can only set that path by rightclicking the little R.
again I am wondering if this is intentional and I'm just not getting it. If so, I would love to learn about the reasoning behind it.
Cheers
Paul
from
Studentenfunk Regensburg
Re: Odd Behaviour regarding REC file locations
I don't fully get your point (can you maybe share a screenshot)...?
The MAIN channel has no 'REC' button. There is not even a little 'R', but a 'REC' button.
So what recording do you mean? - I just tested all channels after changing the default Rec. location by pressing each REC button and new files have been created in the newly set location - nothing wrong.
So can you maybe exactly explain your steps to reproduce.
Any News?
