column chooser in MetaData Editor
Michel67
Post by Michel67 »
When I create playlists with the MetaData Editor, I'm missing in the column chooser "Age Last played (days) ". Is it possible to add this?
Re: column chooser in MetaData Editor
No, as the ‚Last Played Date‘ is only available within ProppFrexx, but not in the MetaData editor.
You can also not generate playlists with the MetaData Editor - this function is also only available within ProppFrexx OnAir.
Ie. use PFOA for it.
Michel67
Post by Michel67 »
Thanks for the reply. I found it easy to create playlists with MetaData Editor (even on another computer that doesn't have PFOA installed). On the left are all the song folders from which I could create any playlist using the trackboard. Moreover, I had all the options (PFL, edit tags, etc.) at hand without burdening the PFOA.
And that tool is for free ;-)
Sorry, it has limits for good reason.
You can simply purchase a 2nd license (eg. Basic) for small money, use the Explorer Window, Media Libs, History Stats etc. or all the other great features…
