ID and talk files fading like music files
Cabzy
Post by Cabzy »
I’ve observed folders containing ID or talk files are fading the same as music files. I create the folder and, as always assign the appropriate media type (Talk or ID). But when the file plays it fades before talking is complete, music starts playing over the file.
This started about 1 month ago.
Do you have any suggestions on what may be causing this?
Thanks.
Re: ID and talk files fading like music files
I assume it might be an ACPD issue?
But without further details I can not really tell. A quick here just shows me, that the media type is correctly set and as such the defined mixing settings apply correctly for that media type.
May be you can try to suppress ACDP for such media types, to see if that helps?
Cabzy
Post by Cabzy »
Thank you
ACPD for talk was incorrect.
