VT Att Volume behind Local Cartwall
henkie86
Post by henkie86 »
i find out when you have openend the local cartwall in the VT window and you click on "Attenuate Volume" the save and cancel button are behind the local cartwall.
You can easily drag the att window up, maybe it can be programmed to be a bit higher so you have not to drag the window.
Thanks in advance.
Re: VT Att Volume behind Local Cartwall
Sure, I'll take a look!
Fixed in v4.5.2.10
henkie86
Post by henkie86 »
Thank you very much :-)
