Stream Broadcast and Interrupt to Play Ads in a Region
This forum is unmoderated!
marinohb
Post by marinohb »
Hello
I'm partnering with another station, that doesn't use Proppfrexx, Im looking to rebroadcast their radio show and get "a signal" when Station A ad breaks comes so I can play our local ad break And start again the show when Station A stops playing Ad Breaks. Is there a way to do that?
Re: Stream Broadcast and Interrupt to Play Ads in a Region
What kind of signal are you looking for?
E.g. the ProppFrexx Station can start their Advert Break with a TCP command you react on. All this needs to be implemented/configured manually.
In addition ProppFrexx has a build in Multi Region Advert feature. Here are some links explaining this:
viewtopic.php?f=4&t=1744
viewtopic.php?p=16626#p16626
