*[TIME:${now}:{add}:${playtime}:{hh_mm_ss}]
atlantic
Post by atlantic »
Can this formula work:
This should result in something like:
(${now} + ${playtime} = 15_21_31
Re: *[TIME:${now}:{add}:${playtime}:{hh_mm_ss}]
The format of the macro function is:
*[TIME:{value}:{add}:{num}:{format}]
The brackets are part of the syntax - you are not using them... i.e. don't remove them, even when using inner macros.
Example:
*[TIME:{15:26:03}:{seconds}:{185}:{hh'_'mm'_'ss}]
{value} : The original time format (as a double or in '[d.]hh:mm:ss[.ff]')
{add} : the conversion function name (ms, seconds, minutes, hours, ab', none)
{num}: the number of units to add as a numeric value according to the conversion function
{format}: the format of the resulting time string (hh, mm, ss; other characters must be enclose it in single quotation marks)
So what is all wrong in your code example:
a) don't remove the brackets
b) the macro ${now} is resolved as a date and time string and not to a time value as expected by the function
Use the ${HH}, ${mm} and ${ss} macros instead to create a time value accordingly (add the colons in between)
c) Use a conversion function (instead of add, e.g. use ms
d) the ${playtime} does not resolve in a numeric value, but a string. I.e. use the ${playtimems} value instead.
e) the format string is not correct, other characters must be enclosed in single quotes
So the correct command function should look like this:
*[TIME:{${HH}:${mm}:${ss}}:{ms}:{${playtimems}}:{hh'_'mm'_'ss}]
Let's assume it is 2026.01.22 15:26:03 and the playtime of the track is 3 minutes and 5 seconds (or 185000 milliseconds).
First the internal macros are resolved, so the function will now look like this:
*[TIME:{15:26:03}:{ms}:{185000}:{hh'_'mm'_'ss}]
As such, 185000 ms are added to 15:26:03, which will result to 15:29:08. And this is now formatted to: 15_29_08
atlantic
Post by atlantic »
Thanks for the tip!
