TCP close?
Thijmen
TCP close?
Post by Thijmen »
Hi there,
I heavily use the TCP connection and it just occured to me, that when testing a script, the ping timeout is visible in the output console:
20-1-2026 21:20:34: Processing Script-Line 6 (Retries=4000): 1 LeastRecentlyPlayed : ALLES (Filter=~[Rating] <> '20', Options=None)
20-1-2026 21:20:34: System.Exception
Client Ping timeout!
   at cv.mV.Fk75(Object  , FirstChanceExceptionEventArgs  )
   at ProppFrexx.RemoteControl.RemoteControlTCPClient.ikwG()
   at System.Threading.ThreadHelper.ThreadStart()
Which makes me wonder: do I need to say goodbye via the TCP? I know that for long-lived TCP connections you need to send the PING command, but my TCP connections are shortlived.
Re: TCP close?
Yes, but this is just an FirstChanceException, which is gracefully caught. So no worry and no issue.
Thijmen
Re: TCP close?
Post by Thijmen »
Okay - so to confirm, even though the stack trace is visible in the debug log when testing a script, it is fine to see the exception. Thanks :)
