D&R Auron
owienk
D&R Auron
Post by owienk »
Is there already a connection available for the D&R Auron mixer, or has anyone connected this console to Proppfrexx?
atlantic
Re: D&R Auron
Post by atlantic »
As far as I know, there is no standard, ready-made connection profile specifically for the D&R Auron in ProppFrexx. However, since the D&R Auron supports Ember+ (just like LAWO consoles), integration should in principle be possible via the Ember+ protocol.
If needed, you can use generic Ember+ browser or monitoring tools (such as those from LAWO) to inspect the node tree of the Auron and then map the required parameters (faders, mutes, sources, etc.) in ProppFrexx.
Re: D&R Auron
Correct.
