Track loses Applied Ruleset
robke
Post by robke »
At random i notice some tracks lose a bit of it's tag-info. Right now i've noticed a track, which should only play in summer, no longer has a Applied Ruleset for 'Zomermuziek' attached. It happend before, but seems random. Any clue what it could be?
Re: Track loses Applied Ruleset
No.
But what do you mean exactly?
A) Is the TAG info (the rule set of the track) suddenly missing?
B) Or is the rule set still available, but not applied?
robke
Post by robke »
Fair point.
The Rule set is still available, but no longer linked to this track as an Applied Ruleset. It was before.
This problem happens with different tracks and different Rulesets.
What is your test scenario? How do you validate it?
And what do you mean by ‚the rule is still available‘?
And what you you mean by rule set?
Can you show me your configuration via a screenshot?
Maybe you are using the different test data it meta data?
For example you can define what meta data takes priority in your general settings and meta data (including the track rules) can be saved to
a) the track itself
b) the playlist file
c) the .pfmd file (if enabled)
So my questions are:
- what is priority setting?
- how/where do you store your meta data in?
- playlist, track, .pfmd file?
How do you test your rule? Via a script?
How does the script look like? Or via a playlist?
Any News?
