Command to get user command names
Thijmen
Post by Thijmen »
Hi there,
It would be very helpful to get the actual OnUserX command names (and maybe icon identification (as a string perhaps)) via a tcp command. Could this be added in the future?
Re: Command to get user command names
Currently no plans for that- as the names are only for the internal UI - so I guess you want to build something on top?
Thijmen
Post by Thijmen »
Yeah, I have this webinterface that I build around it :) So thought I would look at options to fetch the names for these commands. Maybe per command basis, or fetch them all with a response with each on a line.
A new GET_USER_COMMANDS will be added to the next version.
Thijmen
Post by Thijmen »
Awesome, thank you so much!
In the latest v4.5.2.7 the GET_USER_COMMANDS command is available.
Thijmen
Post by Thijmen »
Wanted to work with this, but it seems it's not working yet, see screenshots.
Can you fix this in the next release?
Thijmen
Post by Thijmen »
Just making sure this is not flying under the radar. Is there something wrong with my setup?
No, there was a bug of mine.
It will be fixed today!
A new v4.5.3.1 is available, which should fix your issue.
