Question about scripting restrictions
Thijmen
Post by Thijmen »
Hi there,
I wonder how the scripting restrictions is being saved on a track.
I have several hundreds of tracks I want to change for NOT picked when month.
So, I figured I created a small script for it, since mass-tagging for these restrictions is not possible yet.
There is the TXXX:PFRestrictions which looks like this:
"00:00:00|00:00:00|0|1023|00010101|00010101|True|$0"
I assume some bitshifting is being done to generate the 1023, (which is every month but november and december).
Am I right here? Can you elaborate a bit on these values?
Re: Question about scripting restrictions
The PFRestriction has a minimum of 8 values or more - according the editor values separated by '|' or ';':
1. TimeStart (hh:mm:ss)
2. TimeEnd (hh:mm:ss)
3. Days (combined flags, see below, OR)
4. Months (combined flags, see below, OR)
5. DateStart (yyyyMMdd)
6. DateEnd (yyyyMMdd)
7. DateRepeated (if True, the year in the previous date range is ignored)
8. optional list of RuleSets (also separated by '|')
8./N. '$'+NoRepeatDays (do not repeat in #days; prefixed by a $ char)
Days:
Sunday = 1,
Monday = 2,
Tuesday = 4,
Wednesday = 8,
Thursday = 16,
Friday = 32,
Saturday = 64
Months:
January = 1,
February = 2,
March = 4,
April = 8,
May = 16,
June = 32,
July = 64,
August = 128,
September = 256,
October = 512,
November = 1024,
December = 2048
In your example 1024 = November, where as November OR January would be 1025; November OR December would be 3072.
The RuleSetList is optional, e.g. the PFRestriction value might look like this:
// No RuleSetLIst given (not played in Nov. or Dec.; not repeated within 2 days):
00:00:00|00:00:00|0|3072|00010101|00010101|True|$2
// 2 RuleSets given (only played between 13.11. and 26.12.):
00:00:00|00:00:00|0|0|20241227|20241113|True|MyRuleSet1|MyRuleSet2|$0
Note, for EXEC_TAG_FILE and the pfrestrictions TAG you can use a semicolon (;) as a separator for the restrictions.
Thijmen
Post by Thijmen »
Thanks Bernd! I think I can solve my challenge with ruleset. In the example below I've applied a ruleset:
"00:00:00|00:00:00|0|0|00010101|00010101|True|MYRULESET|ANOTHERRULESET|$0"
I assume the rulesets are until |$0?
Thijmen
Post by Thijmen »
And am I right this is saved under IPFR in WAV?
The $0 is coming from the last NoRepeatDays value.
If you want to tag your MP3s do it according to the ID3v2 specs, which I cannot explain here - there are many official pages.
Yes, the entire ‚ProppFrexx’ meta data xml string is saved in the Riff Info block ‚IPFD‘ of a wav file. Whereas the ‚PFRestrictions‘ are saved in ‚IPFR‘ block of the Riff Info chunk.
Thijmen
Post by Thijmen »
Would it be possible to add support for the restrictions and such to EXEC_TAG_FILE in the future?
I will think about it - but you would have to format the content yourself and it would be on your own risk!
Thijmen
Post by Thijmen »
Yes, that's fine :) I wonder how this would work, since the | is already a separator for EXEC_TAG_FILE. Perhaps;
EXEC_TAG_FILE_RESTRICTIONS file.mp3|00:00:00|00:00:00|0|1023|00010101|00010101|True|RULESETA|RULESETB
Perhaps that works?
I will let you know, once I thought about it...
Thijmen
Post by Thijmen »
Cool - this would solve a lot of work for me :-) Since I find it dangerous to alter the tracks myself (especially with different file formats, like flac, wav, mp3 etc), I would like Proppfrexx to handle this as it's source of truth.
