Faderstart Midi
Feiko
Faderstart Midi
Post by Feiko »
Some help plz;
i'm using a Qconpro Icon midi mixer and want to fader start A between pitch bend two value's .
I've now something like this
0xE5 =0x6D 0x0012-0x0032 PLS_CURENT_PLAY_A
but it is not working, can you help me plz
Feiko
Re: Faderstart Midi
What event and MIdi message does the Monitor show (see general settings and click on the Monitor button next to the MIDI device)…
Feiko
Re: Faderstart Midi
Post by Feiko »
MIXER_OUTPUT_VOLUME_SET A|0.023622047
MSG: 0xE5 0x00 0x03 [Channel 5 PitchBend PitchBend=384]
CMD: Status = 0xE5, Data1 = 0x00, Data2 = Any
Feiko
Re: Faderstart Midi
Post by Feiko »
Oke he works but if I use on this fader also MIXER_OUTPUT_VOLUME_SET A|${mididata2asvol} then it does not working any more.........
Re: Faderstart Midi
What exactly works? The fader start?
Note, that setting the volume, e.g. via MIXER_OUTPUT_VOLUME_SET A... wouldn't trigger another MIDI message.
E.g. you might add another mapping for the fader start?
Or, if you already control the ProppFrexx Fader by MIDI messages (and that is working fine), you can use the 'OnFaderStart' resp. 'OnFaderStop' command of the mixer, i.e. right click on the mixer name and select 'Edit Control Command Events...'
Feiko
Re: Faderstart Midi
Post by Feiko »
Tnx a million
