Whats That ??
DJSven
Whats That ??
Post by DJSven »
Now in moment ist propfrixxonair.exe not longer on the disc not delited not in trash not longer on disc - ok i istall the software new now in disc - 1min later the app close and der exe is not longer on disk ??? help i can not run the progemm longer
Re: Whats That ??
I don’t really understand your scenario. Can you describe what you mean a bit more clearly?
Can you please post your license keys to me privately?
Maybe your are using a hacked or invalid key or version?
Eg. ProppFrexx would close itself, if you are using a deactivated or invalid registration key.
DJSven
Re: Whats That ??
Post by DJSven »
i think so - you thinking i hafe a hacked version - but i hade by 2 lizens of you [email protected] - were cane i see the lizens
DJSven
Re: Whats That ??
Post by DJSven »
oh í see [email protected] druck-expert UG
DJSven
Re: Whats That ??
Post by DJSven »
but 1 luckey info - in older version i cane start but the the new version is deleted from the hard drive - maybe user
Re: Whats That ??
I am sorry, but I can hardly follow what you say.
I only say, that when a deactivated license is used, that in such case ProppFrexx is closed.
I don’t maintain your licenses, this is up to you. But I can tell you, if a certain Ident-Number is active or was deactivated.
And yes, you have 2 active and one deactivated licenses.
