DDos Attack
DDos Attack
Dear customers,
we have faced a huge DDoS attack to our website in the last days. And it is still going on. Hence we had some outage in the last 2 days.
We have taken action and measurements to prevent these attacks and are back online.
Many Thanks for your understanding and patience.
Greets,
Bernd
sokl1
Re: DDos Attack
Post by sokl1 »
Dear Bernd,
Is it the reason why we cannot update ProppFrexx anymore ?
Check for Updates
Check for Updates failed!
Could not connect to the radio42 server.
Please try again later or check your network and proxy settings.
The remote server returned an error: (403) Forbidden.
That's quite urgent as we're now in version 4.5.1.1 and face GPIO client issue. We've been to download that version through the online form but it seems to not be the last one. Thank you in advance. Best regards, Jonathan
Re: DDos Attack
It might be related and I’ll double check!
But in the latest versions since your update nothing related to the GPIO client was added. So I doubt, that your issue is related to that. It more like needs to be solved in your environment?
Re: DDos Attack
The "Check for Updates..." function should work again!
