jingles
Johnny_
jingles
Post by Johnny_ »
Hi
The jingles are cutting off, is there another way to solve this, I use the cartwal player. We have more than 5 thousand songs in the database, at the end of the jingle they are currently cut off.
You can listen to it on kleinepiraat.nl
Greets
Johnny
Re: jingles
Make sure the cue points are either set correctly! Set the ACPD mixing settings accordingly for that media entry type. Or even disable the ACPD feature entirely for those media entry types.
