Error edit tag.
Andre Kroon
Error edit tag.
Post by Andre Kroon »
Hello, Bernd after the last update i get this error when i want to edit a tag in the explorer.
12-3-2025 20:07:41 [v4.5.0.7]:********** Error/Exception Information **********
Error Message: The TokenEdit cannot display tokens with the same TokenEditToken.Value property values. Please set a unique value for the '' token.
Error Source: DevExpress.XtraEditors.v24.2.Void ThrowInvalidTokenException(DevExpress.XtraEditors.TokenEditToken, System.String, System.Exception)
Inner Exception: Item has already been added. Key in dictionary: '' Key being added: ''
at DevExpress.XtraEditors.TokenEditExceptionHelper.ThrowInvalidTokenException(TokenEditToken token, String propertyName, Exception innerException)
at DevExpress.XtraEditors.TokenEditTokenCacheBase.AddItem(TokenEditToken token)
at DevExpress.XtraEditors.TokenEditTokenCacheBase.DoUpdate(RepositoryItemTokenEdit properties)
at DevExpress.XtraEditors.Repository.RepositoryItemTokenEdit.OnTokenListChanged(Object sender, ListChangedEventArgs e)
at DevExpress.XtraEditors.TokenEditTokenCollectionBase.RaiseListChanged(ListChangedEventArgs e)
at System.Collections.CollectionBase.System.Collections.IList.Add(Object value)
at ProppFrexx.TAGEditor.wZQB()
at ProppFrexx.TAGEditor..ctor(MediaEntry track)
at ProppFrexx.BrowserTree.bO0V(TreeListNode )
at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraEditors.XtraControl.WndProc(Message& m)
at DevExpress.XtraBars.Controls.CustomControl.WndProc(Message& msg)
Error Message: Item has already been added. Key in dictionary: '' Key being added: ''
Error Source: mscorlib.Void Insert(System.Object, System.Object, Boolean)
at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
********** End **********
Re: Error edit tag.
Are you in the ProppFrexy Tagger or OnAir?
However, it sounds,like a specific audio file has an invalid TAG? Incan not see from the message, which TAG exactl it is, but it is probably the new Gender or Country?
These are multi value fields (separated by either a semicolon or slash character). However, each of those values must be unique.
And in you case that particular TAG field seems to be not unique.
I assume, that the ‚error‘ is not happening with all audio files, but only a very specific one.
So this audio file needs to be corrected first - so that no invalid TAG data should be present.
Andre Kroon
Re: Error edit tag.
In Onair and the error is with all audio files.
In tagger is everything fine.
The new Gender or Country tag is empty, i didn't change anything.
Andre Kroon
Re: Error edit tag.
Just select a random track in the explorer is the error comes up. have anyone else here this problem ?
Re: Error edit tag.
I am currently on holiday, so I can not reproduce that right now. I’ll take a look next week when I am back.
Andre Kroon
Re: Error edit tag.
Oké no problem at all, enjoy your vacation.
Andre Kroon
Re: Error edit tag.
The problem is solved, i'd run back to an older version and update to the latest version again.
Greetings, Andre.
