Gender and Country MetaData Default Values
atlantic
Post by atlantic »
Bernd,
Is it possible to add Gender and Country to the MetaData Default Values ​​in the MetaData Editor?
Re: Gender and Country MetaData Default Values
What do you mean by default values?
Can you explain, from where to get those default values or how to set them?
Eg. there is also no default values for the Grouping, Mood, Style and other values.
atlantic
Post by atlantic »
What I mean is. Is it possible to add these to the list that are already there. So that we can set them ourselves.
Edit Gender List.. and Edit Country List...
MetaData Default Values popup
I see what you mean. Yes. That will be added in the next update!
THX
Added to v4.5.0.6
atlantic
Post by atlantic »
I can't find it in the Default Values, popup MetaData Default Values. In the new version. Or should I look somewhere else?
It is here:
Maybe you din't install the latest v4.5.0.6 ?
atlantic
Post by atlantic »
I performed the new update this morning and I don't get this popup like you do. Maybe the wrong version was uploaded to the server. It does show version 4.5.0.6 on the startup screen.
I just downloaded the latest version (v4.5.0.6) myself and tried it and all was there. Not sure what might gone wrong on your side?
Please try the download here directly yourself: https://www.proppfrexx.radio42.com/down ... te4506.zip
atlantic
Post by atlantic »
It stays the same, even after deleting the files in the AppData folder of Tagger.
