play count location
fjb59
play count location
Post by fjb59 »
Hi. Where is a track's play count stored? I looked in the track's metadata. i didn't see it there. Perhaps I missed it.
Thanks muchly
Re: play count location
They are stored in the Global Entry Statistics!
I.e. make sure that option is enabled (as it is by default).
fjb59
Post by fjb59 »
radio42 wrote: 04 Mar 2025 13:44 They are stored in the Global Entry Statistics!
ok. is that kept in a specific place? i couldn't find anything in the log folder?
No. It's location is the ProppFrexx AppDataUser folder. The file is called "ProppFrexx ONAIR.entrystats".
But it is an internal file, so don't mess it up...
fjb59
Post by fjb59 »
radio42 wrote: 04 Mar 2025 14:52 No. It's location is the ProppFrexx AppDataUser folder. The file is called "ProppFrexx ONAIR.entrystats".
in the subfolder, "4.0"
Ype. there it is, Thank you for that.
Don't worry. I won't. I'm a big boy. besides, if anything goes wrong i'll restore it from the backup.
