Computername changed
WimHP
Post by WimHP »
I have a question for a friend of mine. He has a ProppFrexx license (Awaaz) but he has changed the computer name where PF is installed on. Is it possible to still recover the previous computer name? Or can you link the license to the new computer name?
Sorry for the inconvenience.
Wim
ps: Registred on e-mail [email protected]
Re: Computername changed
The Ident-Number might change when you change the computer name or the hardware.
If the Ident-Number changes, you need to transfer the license.
The process is described here: viewtopic.php?t=2770
You need to send me your current registration data mail (you received from me) together with the new Ident-Number.
WimHP
Post by WimHP »
Thanks Bern,
Meanwhile, we found the old computer name again and put it back. Everything is working again!
Thanks for the quick response!
Greetings,
Wim
Anand
