v4.5.0.0-.7 - stable
Version 4.5.0.0-.7 is out!
What's New?
  • New VO:EndsWithFullLevelOfNextTrack transition
  • RadioBOSS compatibility MetaData option added
  • Password fix in GPIO Client (re-enter all passwords needed!)
  • TAGs Gender and Country added (also for find and filters)
  • EXEC_SEND_EMAIL now also supports attachements
  • ProppFrexx Advertising now supports -config command-line option
  • MusicMaster Nexus support (initial, Audio Sync)
  • New UI- and Audio-Lib version
  • Various optimizations and smaller bug-fixes
  • stable
ATTENTION!!!
You MUST re-enter ALL passwords in the GPIO Client app due to a bug, which might lead to an out-of-memory error.
The following command-line parameters have been added to the "ProppFrexx Advertising .exe":
-config=path
robke
Re: v4.5.0.0-.1 - stable
Post by robke »
Since installing this update PF crashes on the overlay-player and with the 'play next'-option (F9). It also crashes in manual mode when a track needs to end and eject.
I've never had these issues before. Any idea what to do?
atlantic
Post by atlantic »
Here too the same problem, when changing the hours everything gets stuck.
This is indeed very strange - so please revert to the previous version or download from here (until I investigated what is causing the crash):
https://www.proppfrexx.radio42.com/down ... te4445.zip
Re: v4.5.0.0-.2 - stable
An audio lib .dll was indeed defect, so I needed to replace it with the propper one.
Now it should all work in the new v4.5.0.2 ! Sorry for any inconvinience. And have a happy New Year 2025!!!
Michel67
Post by Michel67 »
best wishes for 2025. Virus scanner finds "Heuristic.HEUR/AGEN.1329739" in pfremcmd.exe during update. false alarm? file is now quarantined, PFOA is just running
Yes, that is a false positive of that scanner. I just scanned it online by more than 100 engines and they didn’t find anything.
So pls report this false positive to your scanner - as I cannot do this.
SevenSenses
Post by SevenSenses »
A nice New Year's present:-)
Yes, this version runs super fast, I used 4.4.4.0 for a long time because all the others had problems with the performance. (GUI)
This one runs super fast again like in the old days.
Thanks Bernd
robke
Post by robke »
radio42 wrote: 31 Dec 2024 17:37 An audio lib .dll was indeed defect, so I needed to replace it with the propper one.
That fixed my problem. Thanks a lot.
Best Wishes for 2025!
claudius06
Post by claudius06 »
Happy New Year and thank you for this update.
Can you tell me more about the new UI and Audio Library version?
