AAC+ & Winamp
This forum is unmoderated!
mixmog
AAC+ & Winamp
Post by mixmog »
Is it still the case that Winamp is required to use AAC+ for streaming?
I am trying to setup Icecast streaming using AAC+.
Winamp is installed, the required executable is available in the "Encoders" folder, I have restarted the PC, restarted PF yet I am still presented with "The selected encoder is not available! Make sure the encoder is propperly installed!".
Please can you give me a hint as to how the encoder should be installed? Does Winamp need to be installed to a particular location? Should I specify the path to the encoder?
Re: AAC+ & Winamp
In the current version yes. That check will be removed in the next version.
You can eg. download the old Winamp version from here:
https://filehippo.de/download_winamp/
mixmog
Re: AAC+ & Winamp
Post by mixmog »
Is there an ETA for the next version?
Re: AAC+ & Winamp
Yes, in the next days…
Re: AAC+ & Winamp
A v4.5.0.0 was just released.
mixmog
Re: AAC+ & Winamp
Post by mixmog »
Thanking you!
