ProppFrexx Crashing
Cabzy
ProppFrexx Crashing
Post by Cabzy »
I assembled a new PC to enhance an ageing server that runs my current Proppfrexx. However, upon launching the Proppfrexx, it would crash after just 3 to 5 seconds. Interestingly, all other applications on this Windows 11 machine were functioning perfectly. After conducting memory tests, reinstalling Windows, and scouring the internet for solutions, I decided to take a look at the BIOS firmware and discovered it was one version outdated. Once I updated the firmware and rebooted, Proppfrexx ran smoothly without any crashes. If you’re building a PC with a Pro B760m-p motherboard, you might encounter a similar issue—so be sure to check your BIOS version!
