Using radiocaster for streaming
- Soulmaster
- Contact:
Hey Bernd
I'm not using the build in stream option but Radiocaster. But radiocaster show not the now playing.
Re: Using radiocaster for streaming
Sure. From where should radiocaster get it?
But you can update the stream title also from ProppFrexx - just configure a streaming server with all credentials, but don’t connect it (ie. don’t stream)
- use the Streaming.OnSongTitleChanged event and send a manual command to update the title.
- Soulmaster
- Contact:
oké then i have to look for somebody to fix this. last time i changed someting and needed a brand new install. I don't get it al those commands.
Was it once working?
If yes, maybe you have already used the "Streaming.OnSongTitleChanged" event with a related command! Or you used a streaming server entry, which doesn't stream, but only sends the meta data to the server? w
As said, you configure a streaming server entry within ProppFrexx (with all credentials, incl. the admin user and password) but never connect this instance. In this case, this instance will only submit and update the meta data to the server, but does not stream.
What have you changed, so that it is not working anymore?
- Soulmaster
- Contact:
Got it
thnx
