An idea about used songs
This forum is unmoderated!
Erris
Post by Erris »
Hi all,
I got to ask this, on Jazler (test version) i found something like this: when i add a song to the playlist and i run that song it does not matter it is auto or live assist, in the library it will be marked as used, and i mean visible like a stroke trough the song. Quit handy because you can see wat has been used instead of searching trough the whole system to find what you used.
Is something like that on ProppFrexx?
And how can i activate is?
Re: An idea about used songs
ProppFrexx also records each track in the global song history, if you configure it to also do that while in manual mode. See the general settings, Log/History and the History settings, ie. set it to ‚Always‘ - the default is that this only happens when the Scheduler is running.
So the feature already exists.
