Qcon pro
robbedoeske
Qcon pro
Is someone use this device and wil share any information/files with me please.
Re: Qcon pro
I know the device (which is great) but I guess there is no remoting interface to it. But I am not sure, if that is needed.
robbedoeske
Re: Qcon pro
I have the device connected to proppfrexx with usb and it has several modes like cubase etc. It has also a learn mode, in this mode i see activety in the monitor window. I was hoping someone has configuration files.
Re: Qcon pro
I just scanned the manual. The Qcon Pro seems to support general MIDI. So it should be fully configurable with ProppFrexx.
However, I don’t have any ready made mapping for it available.
robbedoeske
Re: Qcon pro
Oke Bernd many thanks, i wil try to figure out the mappings, I think it must be in cubase mode then i see activation in the monitor window. Wil try more this evening.
Re: Qcon pro
I don’t know which mode will work. But the manual talks about a separate general MIDI mode.
I would assume, that Cubase mode only works for Cubase.
robbedoeske
Re: Qcon pro
Strange: i have mixer with DJ A DJ B and DJ C when i try to map a fader to DJ A and press Test i got a message "ERROR: no mixer selected"
I have selected DJ A ??
Re: Qcon pro
Not sure where you are. Can you post screenshot.
robbedoeske
Re: Qcon pro
Have to figure out how to post screenshot ...
Re: Qcon pro
First save your screenshot as a file (eg. via the Windows+S keycombo). Then use the full editor in this forum and add the file as an attachment.
