Templates import wizard.
westendradio
Post by westendradio »
Hello, when I want to run template wizard, proppfrexx completely freezes. I then have to close proppfrexx and restart it. Anyone have an idea what the problem could be.
Re: Templates import wizard.
You mean the playlist template wizard?
(as there is no template import wizard)
If it is the playlist template wizard, you are using a program and with this a script to generate the playlist.
I assume, that the script runs very long (probably due to a history issue).
So please use the Test function of the script to see, where and why it is not finishing.
If you believe that there is a crash, see the ProppFrexx Error.log for any entries! And post them to me.
Else take a look to the Windows Event Log, where every application crash will be recorded.
