Strange popup
claudius06
Strange popup
Post by claudius06 »
This morning, a popup "dwnFlash" appeared with an icon representing a shield. What is this about?
Thank you,
Claude.
Re: Strange popup
Can you send a screenshot - but it sounds like it is not from within ProppFrexx.
ProppFrexx is also not using Flash.
claudius06
Re: Strange popup
Unfortunately, the popup disappeared quickly, so I can't provide you with a screenshot. I hadn't thought at all about the obsolete Flash technology, but perhaps I visited a site that still uses it. In any case, thank you for your response, and I will try to capture a screenshot if it happens again.
claudius06
Re: Strange popup
I have the explanation and I apologize for bothering you for nothing. It was simply a notification informing me that PF was downloading the news file for broadcast.
Thank you,
Claude.
