Standby Players
WTCS-FM96
Standby Players
Post by WTCS-FM96 »
When I click on the Standby Player icon, they open up in full screen with no options to minimize or drag to another location. I can only Alt-F4 to close it. There is no border. ?? Any magic to get it out of full screen mode? It completely covers the PF window underneath.
Rick Winslow
WTCS-FM 96.1
Re: Standby Players
Hi Rick,
can you send a screenshot, as I can not reproduce this here.
Do you mean the icon in any dock panel container or which Standby Player icon do you mean?
Or the one in the ribbon tool bar of the View tab?
Maybe the layout got accidentally set to cover more then your screen size - as every dock panel has a header bar and a border.
However, if nothing helps go to the general settings, section 'Look And Feel' and click on the 'Layout' button next to 'Reset' !
A restart of ProppFrexx required after.
WTCS-FM96
Re: Standby Players
Post by WTCS-FM96 »
When I click the View tab, the Standby Players, I get the image shown. The only way out is to Alt-F4 which gets me back to the PF screen.
Like I said there's no way to resize it or go from full screen to a window.
Screenshot
Screenshot
Re: Standby Players
Then reset the layout as explained.
WTCS-FM96
Re: Standby Players
Post by WTCS-FM96 »
:D That fixed it.
