problems wit myradiostream.com
Johan
Post by Johan »
We use as a streaming platform myradiostream. When we enter the stream settings in propffrexx and use the internal stream tool of propfrexx the stream interrupts after x number of seconds continuously.
With rocket we don't have this before. The setup is pf to rocket = no problem.
As a test we have from a colleague friend put his stream in propfrexx and there it works perfectly.
Are there still people who have problems with myradiostream and how this solved?
Thanks.
Re: problems wit myradiostream.com
As ProppFrexx is 100% SHOUTcast and ICEcast compatible and I don’t experience any issues with other streaming servers, I assume, that the issue is somehow on the myradiostream side.
Maybe they can investigate on their side what is going on. It sounds either like a buffer issue or that myradiostream disconnects the stream continuously?
They for sure have detailed logs to see the exact reason. Have you asked them?
Johan
Post by Johan »
Bernd,
Not yet i will do. Maybe had other pf users with myradiostream the same issue. From there my question.
