Starting ProppFrexx with parameters vs. Watcher
doobeedoo
Post by doobeedoo »
Hi Bernd
Our ProppFrexx is started with parameters -config and -globalconfig. Yesterday the program crashed (out of memory) but when the ProppFrexx Watcher restarted the program it did so without the parameters. So we got the startup windows asking for the audio setup.
I've noticed the same happens when we update ProppFrexx.
Is there a way the parameters can be included in ProppFrexx Watcher and when ProppFrexx is updated?
Kind Regards
Bernard
Re: Starting ProppFrexx with parameters vs. Watcher
Normally those parameters are kept and should be used - so I have to try your case… I am currently on holiday and will do so next week when I am back…
