Metatag visible with live prgramm URL
WimHP
Post by WimHP »
Put metatag (title / artist) by default in PF for 'live' programming. I have several live programs weekly whose stream URL I put in the script. Only these live programs do not send a MetaTAG along with them. Can I put a MetaTAG somewhere in the script by default so that it is visible on the various players?
Thanks in advance for the answer.
Wim Zonneveld
Hollands Palet
Re: Metatag visible with live prgramm URL
Are you using the LoadTrack script line to play a stream ULR? If yes, by default the metadata of the stream is used.
If the stream does not contain any metadata you can set it, when clicking on the ‚T‘ in the script-line.
WimHP
Post by WimHP »
Yes, i use thwe LoadTrack script to play stream URL. I have put the T and fill in the info but it is still not visible.
Wim
How are you testing things?
As here in my tests if transmits the Title to the streaming server.
WimHP
Post by WimHP »
Hello Bernt,
I don't have a test environment. I introduced it to an existing livestream of which I have quite a few running.
Wim
You don’t need a test system. How do you reproduce your issue - as I can not.
