Disable Cover in Find window
robbedoeske
Is it possible disable cover in Find (search) window? It seems it slowdown searching a bit.
Re: Disable Cover in Find window
Yes, you can customize the columns as you like.
Make a right-click on the column header and select the Column Chooser tool…
Now you can drag and drop the columns from/to the chooser tool to add/remove the columns.
robbedoeske
Yesss this improved searching a lot thanks
