Instellingen vellenman kit
westendradio
Hello, can someone explain to me how I can get a vellenman kit working with proppfrexx and behringer dx2000 for button start operation. or can and will someone provide a screenshot of his settings.
Re: Instellingen vellenman kit
The Velleman kit is a contact closure device. Ie. when a contact is closed, its state changes from 1 to 0 or the other way around.
So first make sure, that this is working properly with your Behringen! You can test this with the Velleman test app.
In ProppFrexx you can now configure a control-command and associate it with each state, 0 and 1.
In the ProppFrexx GPIO app, you need to enable the ‘GPIO Ext. Service’ (see general settings, section GPIO), you can now enable the Velleman service and configure the mapping of a state (and port) to such control command.
