Replay playlist from the day before
Bernarddemol
Post by Bernarddemol »
Hello
Is it possible to retake a playlist form the day before in proppFrexx automatic?
Good weekend
Re: Replay playlist from the day before
Yes. This is of course possible.
The easiest way is to use the Archive script option.
Archive: Defines an optional archive playlist file in which track entries will be saved which are being used during the script execution.
You can then later use in another script this Archive playlist with the LoadPlaylist script-line mode. This would then load this Archive file and play it.
If you need to replay an entire show including any eg. microphone input as well, you need to record the sum mixer channel. This wg. into a single mp3 file.
So instead of playing a playlist, you now would use the LoadTrack script-line to play such file.
Both options are explained here in detail:
viewtopic.php?p=10805
