Remote View - monitoring?
Steve FamilyRadio
Post by Steve FamilyRadio »
Is there a option for using more then one instance of Remote Viewer on a pc?
We have around 10 stations all running on ProppFrexx, and where thinking about a sort of monitoring view - where we could see all the stations through remote viewers.
Or would you have any suggestions?
Thank you.
Regards,
Steve
Re: Remote View - monitoring?
Currently the RemoteView is limited to be started once per PC - but that limit might easily be lifted, so that you can connect each 'instance' to different server.
What station/license are we talking about - as I can not recall 'FamilyRadio' as a licensed domain?
In the next version, I will add the following command-line options to the ProppFrexx RemoteView application:
-allowmultiple : if set, multiple instances are allowed
-server address : specify the full server address and as an optional parameter (e.g. localhost:9042)
-password secret : specify the server's password as an optional parameter
Regardless, please what station/license are we talking about - as I can not recall 'FamilyRadio' as a licensed domain?
Steve FamilyRadio
Super, thank you for the reply!
Would it also be possible to see the name of the station on the remote viewer?
I have send you a pm with a answer to your question about the license :)
Regards, Steve
Thanks for the info.
I’ll take a look regarding the station name.
Added to v4.4.4.1
