v4.4.4.0-.3 - stable
Version 4.4.4.3 is out!
What's New?
  • New Backtiming display in RemoteView app
  • Script-Testing now shows total time of test output
  • Enhancements RemoteViewer (allowmultiple, server, password)
  • Program Log Import optimized (for hour splits)
  • New UI- and Audio-Lib version
  • Various optimizations and smaller bug-fixes
  • stable
The following command-line parameters have been added to the "ProppFrexx RemoteView.exe":
-allowmultiple
-server=ip:port
-password=credential
This allows multiple instances of the RemoteViewer. As well you can specify the server address and password for each instance.
JFK CoRP
Re: v4.4.4.0 - stable
Post by JFK CoRP »
Hi Bernd, proppfrexx doesn't want to restart after the 4.4.4.0 update, I had to downgrade to be able to restart, the loading hangs when creating the mixer... can you help me please ?
That's strange, as I can unfortunately not reproduce that here. But maybe your mixer setup file got corrupted?
Try to delete your .mixer file(s), which are located in your ProppFrexx AppDataUser folder. Probably you are using the file "Default.mixer".
JFK CoRP
Re: v4.4.4.1 - stable
Post by JFK CoRP »
it worked, I took the opportunity to reinstall the software and switch to the 64-bit version :) thanks for the tip
