acces blocked
This forum is unmoderated!
jbmusic
acces blocked
Post by jbmusic »
Hi all,
i would like to use the remote voicetraining.
System version is upgrade to the enterprise version.
When i try to connect the systems i get the message that the remote is activly blocked the connection.
has this something to do with permisions?
I can not find anything in this fora so therefore this question.
Re: acces blocked
Yes, you can control it in the permission.
But you also need to set the option "AllowRemoteVoiceTracking" in the program scheduler entry. Have you done this?
jbmusic
Re: acces blocked
Post by jbmusic »
Bernd is there A better manual ? When I follow the video it’s stil not working even when I have add in the scheduler the remote voice track option
Re: acces blocked
What exact message do you get. Maybe some screenshots of your setup will help!
Have you setup the GPIO Extension Service?
Details are else explained here: viewtopic.php?p=6297
jbmusic
Re: acces blocked
Post by jbmusic »
Hi Bernd. Issue was related that after the restart from the update i had to re-enter the password. It seems to be not stored .. but it seems to work now
