(Pre)Generate Playlist templates
atlantic
Post by atlantic »
Bernd, the (pre)Generate Playlist Templates no longer work after update 4.4.3.1. The PDF is empty. You will also receive an error message if you create a new playlist via rvt.
https://www.dropbox.com/scl/fi/u49tiajw ... 6hajp&dl=0
Re: (Pre)Generate Playlist templates
Yes, another stupid bug in the new user-rights for RVT - sorry for the inconvenience.
It is fixed in the new v4.4.3.2!
atlantic
Post by atlantic »
Bernd, Thanks for the update.
And News..?
atlantic
Post by atlantic »
Bernd, everything works as it should. Every user now sees their playlist. Perhaps you can create a function under user profiles under rights "Allow change playlist". That the user can change the order of the playlist or remove tracks from the playlist that has already been created.
