Problems with update new version
Barry
Post by Barry »
Hi There,
I Update the new version of PF and after it nothing is starting.
When i press on the button on my board also the program is not starting.
Now i i'm back @ the version before the new 1.
It's the same problem as a x versions ago....
Many more of my team have the same problem and working now on the version before the new one.
Re: Problems with update new version
I did re-upload the new version - may be there was a deployment issue with the initial upload, as also another user reported the same. But all that happened already yesterday 2 hours after the initial upload.
So maybe you also updated in these initial 2 hours?
I also tested it here again and could not find any issues.
I can also see, that various other users updated successfully. So I assume, that the issue is already solved.
Can you also confirm this?
Barry
Post by Barry »
The new version is working good, But i must start PF from the location Progam files / Radio 42 / PFOA / Previous Version.
When i click on the icon on my board noting starting. I try many times and also a restart of the computer the icon is not working.
When i copy the link from my map to my board also nothing is opening.
But no problem.... I opened by the map
Note, that the root issue was immediately fixed with v4.4.3.1!
With each upgrade a folder ‚Previous Version‘ is created, to which the content of the parent folder (the actual installation folder) is copied.
To restore a previous version, you can simply manually copy the content up one level back to the installation folder (you might need elevated Administrator rights).
So if you run and update ProppFrexx from the Previous Version folder, the update also happened there. If you want all in the installation folder, just copy all up one level as well.
