How NO play same artist during xxx time
Vladimir
Post by Vladimir »
Hi all,
i check the sometimes the software play a song 2 times after xxx minuts ... i like to know if exist a command for check and NO PLAY again a song before xxx hours etc.
and where storage the log of playback history ?
thanks for all help !!!
here runnig V. 4.4.2.1
Re: How NO play same artist during xxx time
Why do you post this as a bug?
This is for sure NOT a bug!
See the Tutorial Video ‚History Settings, do not repeat…‘:
viewtopic.php?t=1018
It all depends on your media libs (and their size) as well as your history settings as well as your script.
A common advice is to use the 'LastRecentlyPlayed' script-line mode instead of the 'Random' mode.
The settings can be found in the general settings, section Logging/History.
Then check your global history settings as well as the Global Scripting Restrictions.
Check the 'Keep Global Statistic Log' option to save all played entries in a statistic log - see the tooltip or press the '?' icon at the very top right to get help about each option and where the data is stored.
he 'Keep Global Statistic Log' option also allows the ProppFrexx Statistic app to be used...
Vladimir
Post by Vladimir »
Hi boss, sorry for write in wrong section ...
i check all video's and i understand more stuff about this BIG radio software ... all day a new surprise !!!
Happy 2024 and many thanks for your help !!!
No problem. Start with the tips provided here. Esp. The LastRecentlyPlayed mode.
