Installed recent update and now the program wont open
WickedSpins23
Post by WickedSpins23 »
Hi
I have just installed the latest upgrade and all seemed to load and install without issues at first, but couldn't get anything through PFL. Closed the program and restarted, loading box comes up but when that closes the program no longer opens
Re: Installed recent update and now the program wont open
Sounds like your audio devices changed. Maybe due to a parallel OS update?
Regardless, close PF and remove the file „Default.mixer“ contained in the ProppFrexx AppUserData folder. After you need to perform the mixer setup again…
WickedSpins23
Thanks removing Default.mixer didn't resolve the issue but removing My.mixer did. so back up and running
