MetaData Editor request.
Erris
Post by Erris »
I use MetaData editor of ProppFrexx, but when i have a shitload of directory's i need to expand them per piece.
It would be easy to use expand all so that selecting music files would be easy, if you want to mass change something.
Re: MetaData Editor request.
Expand All is of course possible in the Tagger application, see the context menu.
Else you could also use ProppFrexx, create a new and empty playlist, drag and drop all folders (or the root folder) to that playlist; enable Direct TAG editing in the ribbon tab - and edit like as in the Tagger app.
Once done, disable Direct TAG editing to save all changes.
You can use the column chooser to add all fields you need/want to edit in the playlist view…
Erris
Post by Erris »
That is odd, i found a expand but when i click right mouse and release the expand will dissapear, also it is not opening multiple folders :(
Ahh, now I see your issue - I will add a shortcut and extra menu items for it in a next version!
A new v4.4.1.7 is available (also for the Tagger).
First you can now hold the shift-key to display the build in xpand/Collaps menu.
Else, it adds two new Expand/Collaps menues in the context menu.
1. on the root level - effective for the entire view
2. in the 'Selection' sub-menu for all selected nodes ! (key combo Alt+X resp. Strg+X)
Note, that you might need to disable the 'Auto Collaps' option in the main ribbon to have it really applied for all nodes!
Erris
Post by Erris »
Hi Bern,
Great work, i just read it :) it works like a train :)
