Playlist sets songs played?
This forum is unmoderated!
Bart ve
Post by Bart ve »
Hi. Maybe I do something wrong. I made playlists with voicetracks. When I reload such a list, the songs that are not loaded in a player are set “played” and de playlist stops after 3 items. I filmed what happens, but I can’t share it here. What do I do wrong?
Bart ve
Re: Playlist sets songs played?
Post by Bart ve »
Added info: playlist loads correct and after a few seconds all songs become marked as played. When I toggle the total list; the same happens
Have you checked, if the files are accessible and available?
Or if they do not violate any rules or history settings?
Ie. if they cannot be loaded to a DJ Player (because of eg. the above) they are unloaded and marked as played.
So when they are unloaded you can try to double-click (PFL) or press Alt+3 to see, if they are playable or see, if the file is incorrect…
Bart ve
Post by Bart ve »
Thank you. Settings corrected. Now works.
