Commercial break
atlantic
Commercial break
Post by atlantic »
I have a question. You have a commercial that consists of 2 parts (long and short version). Can you run these in the same block? The long version is the beginning of the commercial break and between other advertisements and at the end of the commercial break the short version.
Re: Commercial break
Yes, you can use the Priority of the campaigns to define their position within the block/slot.
Eg. use for the 'first' campaing a priority of 130 and for the 'last' a priority of -30.
A priority can be used to define the order in which campaigns are played within an advert slot. Campaigns with a higher priority will be played first (e.g. 60, 50, 40, ...).
Note: When using campaign keys this priority might get shifted resulting in campaigns with a lower priority being played first, as the campaign key is evaluated regardless of the priority.
However, priorities above 100 are always played first and priorities below 0 are always played at the the end (regardless their key).
atlantic
Post by atlantic »
Thanks, I'll try that.
