Tracks loaded in playlist with ???
This forum is unmoderated!
Bart ve
Post by Bart ve »
Hi
I’ve a lot of tracks that don’t play when I generate a playlist. They’re visible in de playlist but with ???? in the duration field. These files don’t play.
What can be the reason please? And is there a way to find out which files in the database are affected pls? Thanks a lot. Bart Z-Radio
Re: Tracks loaded in playlist with ???
This means, that the loaded file is either inaccessible or an invalid audio file, which exists physical, but can not be played.
So please check the references playlist entry, possibly the file does either not exist or is invalid.
In your media library (when you open them as a playlist) you can ‚Mark Dead’ files, see the Remove context menu.
