Listeners Graph
Listeners Graph
Could you put on your wish list also include Number of listeners graph and some kind of report in order to be able to evaluate how many listeners did listen at concrete time?
Peter
Re: Listeners Graph
ProppFrexx doesn't collect or store historical statistical data from the streaming servers.
This because in the real world, many stations use multiple streaming servers (relays) to reach their audience. As such the stats would need to be collected from all involved servers. In addition, some users only want the raw listener numbers, other want more detailed stats per country, time, browser etc.
There are mny applications (from simple web based to very complex ones) out there already doing that job fairly fine. So I suggest using some of them, like:
http://www.glop.org/shoutstats/
http://www.casterstats.com/
http://amptracker.com/
http://www.shoutq.com/
http://bellonline.co.uk/downloads/shoutc...ver-stats/
etc. etc.
Just do a bit of googling...
etc. etc.
HarrisClaudine
Re: Listeners Graph
Thanks Bernd, that's quite informative! Even if it's a bit of googling!:)
______________
free mp4 to avi converter
______________
meisterpropper
Re: Listeners Graph
has anyone found a good script? I´ve googled and tried the links above, but for example shoutstats doesn´t work and gives php errors.
Re: Listeners Graph
No, I'm afraid not.
While searching for a solution myself a question came up: What do I need these numbers for aside from "ego reasons"? Is there a technical reason to actually know these numbers? Or a legal requirement?
meisterpropper
Re: Listeners Graph
Because it´s good to know for planing the scheduling etc.?!
Re: Listeners Graph
Your scheduling for the next weeks is affected by how numbers are changing in this very moment?Because it´s good to know for planing the scheduling etc.?!
meisterpropper
Re: Listeners Graph
No, my scheduling is affected by the time, when the most listeners tune in, so I need a daily graph. Sorry, but for doing radio you need a bit empirical data.
Re: Listeners Graph
hello
i cant see my listeners everithnig its ok but my listeners dont work
i have centova cast 2
can eany knows ?
can eany knows ?
